I'd like to run some ethernet cable in my wall through a suspended ceiling to a room where I can terminate the cable. I've not done this before. Most videos show DIYers up in their attic with ample space to grab and pull a wire. I do not have that luxury. I can't fit in the space. How do I get my cable up the wall and then pulled 12 feet through that space without getting stuck on one of the joists?
1Does diy.stackexchange.com/q/267173/135381 help?– red_menaceFeb 25 at 20:25
Miss the olden days. When you could just have some candy and bring a little helper home. These days the candy will get you a swat team.– crip659Feb 25 at 21:28
This one looks perfect for the R/C rock crawler method. :)– HuesmannFeb 26 at 14:50
1 Answer
use a flexible rod with a kink in the end that allows it to ski over obstacles
when I was doing satellite TV installs I used 1/2" pvc conduit for this task.
