I'm looking to install a water filter under my kitchen sink for the cold water line, but I ran into a fitting I've never seen before. I can't find pictures of anything similar when searching online. The water filter's line won't connect with this fitting, so I'm searching for a specific adapter or converter.
What is the name of this type of hose end?
mystery hose end
And this type of quick connector that hose fits into?
mystery connector
    I have only seen these for suppply to the fridge Commented Feb 25, 2023 at 19:14
  • 6
    This looks like some proprietary fitting. Can you give us more context? What's at the opposite ends of the two hoses pictured?
    – Greg Hill
    Commented Feb 25, 2023 at 19:15
  • @GregHill The other end of the first hose is attached to the cold water valve. The opposite end of the hose with the quick connector goes to a pull-out style faucet head. Commented Feb 25, 2023 at 21:20
  • @Armand While that piece is different from mine, I do believe the top answer there still relates to my question! It is a pull-out style faucet head and you can make out "MOEN" on the connector in my second pic. Commented Feb 25, 2023 at 21:24
This is, in fact, a proprietary hose and quick connector made by MOEN. You can make out the brand name in the second photo from the question.
Here's the same connector construction in diverter form:
MOEN quick-connect diverter
Searching online for "MOEN pull out faucet hose" or "MOEN quick connector" will produce results for the same type of hoses and connectors.
Kudos to @GregHill for identifying it as proprietary and @Armand for finding a similar question where the top answer mentions MOEN pull-out faucets specifically.
Yes, as @GregHill suggests, those are proprietary fittings used by the faucet manufacturer to simplify user installation of the faucet (connecting faucet sprayer/spigot to output of faucet control). That fitting connection should be downstream of the faucet control; your filter should be installed upstream of the faucet's cold water supply connection, perhaps at the shutoff.
