I have a MEDAS 1/2HP 1850 GPH submersible pump. I want to use it to water my garden.
Sprinklers sounds good but I worry if I'll have enough water pressure. I was able to connect the pump to a garden hose with a spray nozzle and it looked like good pressure. But spread out over multiple sprinklers across the garden, which is about 30 feet long and 5 feet wide, I'm not sure.
If anyone knows anything about pumps and/or sprinklers, is my pump good enough to set up sprinklers? If so, would you have any advise on implementation?
