So I have been trying to get my shower drain cover off so that I can remove all the hair but I can not seem to figure out how it is supposed to come off. It doesn't have screws, doesn't twist, and doesn't pry off. I am out of ideas. Any tips would be appreciated.
@Ruskes, comment-answer flagged for deletion. Please post properly. Also, the question states that twisting was attempted, so you'd need to enhance your instructions.– isherwoodCommented Feb 23, 2023 at 14:20
2Do you have access from below? It may have a securing nut underneath. More likely it's just stuck and you need to twist harder.– isherwoodCommented Feb 23, 2023 at 14:20
Having just purchased a brand new drain to install into a brand new shower pan, I would suggest that this should, most likely, unscrew.
However, since yours isn't brand new, it likely is rather stuck and needs some help. It's apparent that you've made some attempts at releasing this and have managed to bend it a bit so further care is necessary in attempting to remove it. You'll want the largest flat-blade screwdriver you can find that will fit into the slot right at the center and give it a twist (lefty-loosey) to unscrew it. If that still won't budge it (or feels like you're going to start damaging the strainer) move on to the next steps...
I'd suggest some small amount of drain cleaner carefully poured between the strainer and the trim ring and allowed to sit and soak for a while, then rinse thoroughly (you don't want to splash that on yourself while you're struggling to get this off). That should help break up whatever gunk is binding the threads. You may need a couple of applications. Note that whatever manages to spill down the drain will help break up whatever is clogging your drain. ;)
If a couple of applications of that don't help, you may need a penetrating fluid to work its way into the threads. Many people use WD-40™ for this, though I've found that PB Blaster™ to be more effective on crud-encased, rusted bolts on vehicles. Whatever product you choose (there are more), carefully read the instructions to ensure that it won't damage your tub/shower floor. If it's porcelain over steel, it should be impervious to just about everything, but if it's fiberglass, acrylic, stone or other material, you don't want to put something on there that will stain it or eat away at it.
Once you've got the strainer out, you may be able to hammer the little dimples flat if you have a hammer and an anvil (or something that will work as an anvil). You may want to protect the visible surface finish by using a rubber mallet or a piece of wood if you only have a metal hammer.
This drain seems to be mostly used in mobile homes and RV's. The strainer when new is simply is pushed into place. Until it no longer stays in place because the person that last removed it deforms it (the strainer). Some plumbing forums have some unkind words for this person because of what they do next. Instead if gently reforming the strainer so that it fits the opening the way it should (as mentioned by freeman). They put silicone around the opening where the strainer sits in the drain and press the strainer back in. This makes it nearly impossible for someone to remove without damaging it. I will try scrapping the silicon out with the tines of plastic forks or a X-Acto knife.
I don't have pictures of that drain. However, to clear any confusion as I began scraping around the strainer I was pulling up strips / small bits of non metallic translucent material. I made and assumption it was silicone.
In this picture once you get the strainer off you can see the finish is failing. During the process of getting removed, as I scraped around the strainer I was getting a greyish powder when I continued to scrape after I rinsed and I was getting a grey paste. I worked a little at a time stopping to place a screw driver in the center slot and pry. Finally, the strainer lifted off. In retrospect I should have sprayed something like you would use to loosen rusted nuts (I did think of this at first but did not want to clean up slippery mess). In this case you can see the finish failing. Looking closely you might see the ring where the strainer sat in the strainer body. The strainer I assume is stainless and the body maybe chrome plated aluminum alloy.. Possibly when the strainer was replaced after cleaning it could have started digging into the finish past the chrome into the the aluminum causing Galvanic corrosion known to take place between stainless and aluminum binding the strainer and body together.
2Do you see any evidence in the OPs actual photo that there's silicone in there? I don't. While I agree that someone might do that if it's been deformed, I would think that the type of person who would bend the strainer on the way out, then glue it back in with silicone wouldn't do such a neat of of laying down the caulk that it would be nearly invisible. If you're also having this issue (seems like maybe you are), the please don't post a "me too!" type of answer, which this seems to end up as.– FreeManCommented Feb 23 at 23:06
I see something between the strainer and the strainer body. It's looks grey. Maybe construction adhesive. It could be corrosion that has locked it in place . I updated the post with more detail.– JohnCommented May 3 at 2:24
