EDIT: Sorry, I didn't realize I couldn't ask this question. It is in a commercial type setting (it is a non-profit and seperates a living area from another area).
I need to know what kind of door handle to look for. We have a door access program that uses keyfobs to open the doors. We also need to be able to use a key from both sides of the door (double keyed) in case the power goes out. I need the door to open only, not unlock. Any idea what kind of hardware I need to look for?
    Could you provide a picture of the door you're asking about? Commonly we call a door with a handle that doesn't operate the latch a passage door, but a picture would help immensely.
    – Chris O
    Commented Feb 22, 2023 at 22:06
    Is this in a home or somewhere else? Requiring a key (electronic or otherwise) to exit is unusual, and dangerous.
    – nobody
    Commented Feb 22, 2023 at 23:42
  • Please revise your post title to ask a clear, specific question. Take the tour for tips. I'd make an effort to do it myself but I'm not sure I understand your question.
    Commented Feb 23, 2023 at 14:18
  • If the door needs to remain locked from the inside, you need to seriously consider a "crash bar" type for the inside to allow occupants to exit in a panic (like when there's a fire) so they don't have to fumble with a key.
    Commented Feb 23, 2023 at 14:41
    I’m voting to close this question because this sounds like a commercial installation (without any evidence from the OP that it isn't), and commercial work is off-topic.
    Commented Feb 23, 2023 at 14:42
You already know you can't just push a locked door open, because a thing in the door (the latch) is blocking a thing in the wall (the strike). And of course you know normally, you open the door by having the latch retract. Well, there's a way to have the strike retract instead! So now, either way can open the door.
That is called an electric strike.
You have your badge system operate the strike electrically... and your key system operate the latch mechanically.
This is a very common way badge entry systems are set up. If the electric strike is stone dead, the latch can still be retracted the old-fashioned way.
  • Snark free interpretation: Any old keyed door knob/latch will do the trick, since all the key is doing is retracting the latch and it has nothing to do with the electronic operation. (snark not totally inappropriate in this situation). +1
    Commented Feb 23, 2023 at 14:39
