The package says these nuts can handle the size range 2-18 to 2-14. Is a single 14AWG in that range?
This is going to be a temporary cap off for several months until house is painted and new pergola built. The wires feed porch lights.
front of bag of nuts
back of bag of nuts
    The CE multipacks will include little blue ones, which twist nice and tight on a single 14awg. Feb 8, 2023 at 2:24
12
Minimum is two #18 AWG which would be .00256 sq.in. One #14 AWG is .00323 sq. in. and is less than two #14 AWG so you'll be fine using those wire nuts.
    This may be the most significant-digit complete answer I've seen here! ;)
    Feb 8, 2023 at 12:25
  • This doesn't take into account the insulator. I find that a nut on a single conductor holds WAY better if you don't strip the wire. (obviously only applies to single conductors:-))
    – Jeffrey
    Feb 8, 2023 at 17:49
1 #14 should be just fine. Worst case, twist it as tightly as you can and then add a piece of electrical tape to hold it on.
In general, I think wire nuts don't list 1 of anything because they are officially called wire connectors. If you have only one, you are not connecting anything together. But they can certainly work well with one wire as a protector, particularly if that wire is not at the low end of the range for that particular wire nut - e.g., I would not use this for a single #18.
See also: "The sound of one hand clapping"
Max is 2-14. 1-14 is less.
It might do two 14 gauge wires, but really most people would suggest a larger size nut if at the max.
One 14 gauge will be at the sweet spot for those nuts.
    The diameter may be in range, but you really have to pay attention to the stripped wire length when putting a wire nut on only one wire. When you have multiple conductors twisting together into a spiral, they end up taking less linear length than their stripped length. That doesn't happen with a single conductor.
    – nobody
    Feb 8, 2023 at 0:45
