I want to install two LeGrande RRW600UBCCCV4 motion sensor switches. One on each end of the kitchen area so that the light comes on no matter which entry is used.
From the ceiling I have a black wire and white/taped black and another white that is connected to it.
I went through and disconnected every terminal at both switches and the fixture and ran continuity tests to see what went where.
Then I went back and connected the wires and energized the circuit.
This is where we are at this point, awaiting some instruction.
What I do NOT know is what the use of the blue/white wire is on the new sensors.
Nothing in the wiring diagrams on the sheet supplied seem to address this situation.
First image is all wires disconnected and continuity tested:
Second is wiring connections made and hot circuit voltage tested:
