Here is scenario:
  • House has cement foundation/slab
  • An asphalt mastic was put over foundation/slab as a vapor barrier
  • 5/8 inch plywood put over asphalt mastic and nailed into foundation
  • Heavy plastic put over plywood
  • Hardwood flooring nailed into plywood -- Plywood was completely soaked due to slab leak over a period of time.
We pulled up hardwood flooring (nothing wrong with hardwood floors) and most of the plywood had deteriorated to point of falling apart/mushy.
Questions:
  1. How long could this plywood stay wet between the two moisture barriers?
  2. How long does it typically take for plywood to deteriorate to the point of being mushy?
    Plain internal plywood would probably not take long to be mushy, maybe a month or two. Between two vapour barriers, will take a long time to dry, but it is ruin now replacement only choice. Plywood usually has layers of real wood veneer and fake/particle wood.
    Feb 2 at 1:04
Question 1: - more or less forever, which is why you use ONE such barrier, not two. Trapping moisture between vapor barriers leads to rot...
Question 2: - depends on the quality of the plywood, the temperature, etc. can happen in months under favorable (to the rot) conditions. Could take years.
