How to adjust metal cabinet round pins? Located inside office table cabinet
1 Answer
Yank them out, shove them in.
Depending on the fit and age (or how long they've been sitting in the same hole), you might need a pair of pliers to grab them firmly enough, if fingers alone won't budge them.
Yep. Just grab 'em with some pliers and they should come out. But I've found that sometime they may need a bit of twisting to convince them to loosen. Jan 30 at 15:27
