I've owned this home for about a year and this has always intrigued me. My 2-story home has a supply duct nearly pointing at a return duct in the center of the hall upstairs.
Two questions:
- Would hot air even reach the floor in a setup like this?
- Why are there four here? My assumption is in case all the bedroom doors are closed (even though the bedrooms themselves have return ducts in them), but why 2-and-2?
I'm going to have a HVAC specialist come out eventually anyway since the distant two rooms, as seen in the picture, are about 5 degree difference than the rest of the upstairs. This is partial to why I'm asking though, since it feels like the heat stops from this part of the hall and onward to the two additional rooms past it.
A couple of things to note
- The upstairs is on a separate system than downstairs
- The two "extra" rooms in the back (which are 5deg diff) do NOT have return ducts in them
Any insights would be helpful. Thanks!
