I have leaked a liquid mix of Spray Foam Sealant Dispensing Gun Cleaner and orange spray foam from a garbage bag onto a concrete floor, leaving an orange stain.
What's the easiest way to remove the colored stain?
  • Since it is outside you can try gasoline
    – Traveler
    Jan 23, 2023 at 16:32
    @Ruskes "floor" indicates to me an indoor slab.
    – Huesmann
    Jan 24, 2023 at 13:27
Grind it off. Or paint over it. Solvents don't work once the stuff has cured.
  • would the stuff that's mixed with the sealant cleaner still "cure" Jan 23, 2023 at 16:38
    Probably. Just slower and soaking in more.
    – keshlam
    Jan 23, 2023 at 16:43
  • The cleaner evaporates rapidly, so "mixed with the cleaner" is a very temporary situation. Once the product has cured, the cleaner won't touch it, and I doubt gasoline would either. Uncured, gasoline would work, but acetone (which is mostly what the cleaner is) works fine with less hazard.
    Jan 23, 2023 at 18:08
    Take a torch to it, maybe?
    – Huesmann
Try power sprayer, rent it or buy it.
I use gasoline to wash it off but that is no no for many
