I have a Honeywell T5 WiFi Thermostat. I am running a gas furnace and an AC system that uses the furnace air handler. There are H, R, G and Y wires coming from the furnace. There was an unused 5th wire (blue) that I hooked up to the C terminal at the furnace and on the thermostat.
- The problem is that when the T5 calls for heat, the heat comes on normally but after about 6-8 minutes, the heat goes off, and then after a few minutes it comes back on and then shuts off again after 2-3 minutes. This 2-3 minute cycle repeats until the house temp reaches the set point.
- The thermostat reboots when the heat goes off, so I assumed there was a voltage drop causing it to lose power. I put a meter across the furnace's R and C terminals, and there are +/- 28VAC. Same at the thermostat. When I monitor the R to C voltage at the furnace, I see a drop to about 4VAC just before the furnace shuts off. It then comes back to 28VAC. I have tested the limit switches immediately after the heat shuts off and they have continuity.
- When I put my old 4-wire, battery-powered Tstat back on, the system runs continuously until the set- point is reached without any problems.
- I would like to add a second transformer to provide continuous, clean voltage to the thermostat, but I am not sure if this is OK to do that with this model thermostat. I could add it either at the furnace and use the existing R and C wires (disconnecting them from the furnace terminal block) or I could add the new transformer at the thermostat as the video shows (to the R and C terminals) and disconnect the C and R wires running from the furnace to the thermostat. I could also connect the transformer wires to the Rc and C terminals and remove the jumper between the R and Rc terminals, but I am concerned that having 2 sources of 24VAC to the thermostat would cause problems. The Furnace is a Heil 7000 Model # NUGK100DH08 867.769437 MFG in 1990.
Does any of this make sense with this thermostat? Also, any idea what causes the voltage to drop at the furnace? Any feedback would be appreciated. Thanks for your help.
