I have a kitchen where I have a 15A receptacle on a split circuit (two hot wires and one neutral). Previously, it was set up with the brass connection cut with one hot wire for the top plug and the second hot wire on the bottom plug on the same receptacle.
I wanted to replace it with a GFCI receptacle for safety reasons (within 6' of a sink), and bring my kitchen up to modern code, but I know this is not possible with a split circuit, so I called an electrician to give me a solution and implement it.
The electrician simply put a wire nut on the red wire and screwed the black wire to the GFCI receptacle. This means that half of the circuit is just never used anymore, and the other half now serves the whole receptacle (which is now a GFCI receptacle).
I tried finding other people having done this on the web but couldn't find it, so I'm starting to worry that the electrician probably took a shortcut rather than do the job right.
Should I be concerned, or is this totally fine and up to code?
Edit: There's a bit more to my kitchen situation, but I only mentioned one receptacle (which is alone on its own circuit). Here is a diagram of the full kitchen situation. The receptacle I was talking about above is the one on the left. The receptacles on the right shared a circuit, but when he split them, the one receptacle (in the middle) is the only one that was not within 6' of a sink and the electrician insisted that we didn't need a GFCI there (even though it's a countertop receptacle and I had a GFCI receptacle handy).
PS: I didn't feel like making the ground in my little diagrams.
