Context: I am considering adding 2 skylights (22.5in x 23in)in my dining room. The attic space is very tight and I have only one option so that the skylights are almost centered on the ceiling below. If I use one, it will be off-center. Two makes it almost centered. The rafters and joists are on 24in on center.
Question:
Is it possible to place 2 skylights, side by side, separated by one rafter? That rafter will be shared as a support for both skylights, right between them.
