If I unscrew the bake element from the back of the stove so that the metal plate on the bake element (almost identical to this: https://www.lowes.com/pd/Certified-Appliance-Accessories-Replacement-Oven-Bake-Element-for-GE-and-Hotpoint-WB44K10005/5001581763) does not touch the back of the stove it works fine and does not trip the breaker.
However, if that metal plate touches the back of the stove it trips the breaker if we try and use the bake function.
Model: GE J BP23D R3WW Bake Element is: WB44T10060
This is where the element screws into the oven:
I'm reusing the same screws with the new element.
Any idea where to start?
Edit: I double checked the screws in the back of the oven and can confirm that the screws are not coming into contact with anything other than the insulation:
Note: I know my black and red are swapped (i.e. source red does not match oven red), I was doing testing
