We converted a small garden shed, about 8' x 12' into a small free-standing office space. It works great for that purpose, except the floor (concrete pad) seems to wick water if it rains too much.
We had to take out the first installed floor (laminate over a vapor barrier on top of the concrete floor) because there was clearly seepage and the floor was wet after heavy rain. We have tried a concrete sealer on the pad but it doesnt seem to help. Floor is still getting damp.
The shed is located on a slope, and its gets pretty muddy on the uphill side. We thought about installing a French drain on the uphill side to assist with drainage, but not sure that will help or make any real difference.
Will several more coats of sealant work better? Double layer of vapor barrier beneath the new laminate flooring? Do we need to wait until the end of the rainy season (we are in Seattle) and the floor is completely dry before applying any more sealant? Maybe put some kind of pressure treated lumber frame, and plywood to elevate the floor off of the ground, and install the laminate flooring on top of the plywood?
Any suggestions much appreciated!
