My washing machine drain overflows from the standpipe. The waste pipe has kitchen sink, washing machine and dishwasher connected with dedicated P traps. The dishwasher and washing machine have dedicated standpipes. There is no overflow from the dishwasher standpipe. The waste pipe header goes down below the floor and then comes out to an outside sewer trap. I opened the sink P trap and washing machine P trap, cleaned them and also snaked the line all the way. But it doesn't look like a clogging problem as when I take out the washing machine P trap and leave the pipe open on that side, the kitchen sink drains well with no water backing-up even with a fully open tap. However, when I screw the washing machine P-trap back, the problem comes back. It seems there is air getting trapped somewhere as there is lot of gurgling. There has never been an air admittance valve (AAV) anywhere in the plumbing. The system has been working fine for many years until last few months so it can't be a plumbing design issue.
I noticed the drain hose was going deep into the standpipe so I raised up and screwed the hose clamp higher such that only about 2 inch of the hose goes into the standpipe. Not sure if this will solve the problem. Temporarily put a container below the overflow location to catch water if it happens again but this is not really a solution.
I am an engineer so keen to solve the problem myself before going to a plumber. Any suggestions on what could be the problem?
Thanks
    Could be a vent problem. The vent could be blocked/partial block by outside stuff(leaves/birds/rats/santa). Should have a black(usually) pipe sticking out of your roof by a couple/few feet. This pipe is connected/extending from your main drain line.
    Jan 4 at 21:47
I had the exact same problem. kitchen sink and all the baths drained good, Washer standpipe overflowed. Turned out the main drain had a partial blockage. Plumber cleared the blockage. All is well
    Washers do tend to dump a lot water fast, so they will show a partial blockage first, compare to other sinks/drains just draining the tap flow.
    Jan 4 at 23:12
  • Since the kitchen sink tap drained without backing up with full tap open, it may be as high flow as a washer drain I guess. Both kitchen sink and washer drain through the same drain header into the outside sewer i.e. final disposal point to the sewer is common. If the kitchen sink overflow hole is partially blocked, could it cause this issue? The overflow hole also acts a vent.
    – Newbie
    Jan 5 at 0:36
  • sink overflow vents the drain before the trap, so it only vents the short section before the kitchen trap
    – Jasen
    Jan 5 at 2:26
  • I'm impressed, @Jasen, that you can see through the OPs walls to know how his plumbing is vented!
    Jan 5 at 14:20
  • actually the sink overflow is almost always integral to the sink, if it is indeed plumbed inside the wall I am definately wrong.
    – Jasen
    Jan 8 at 23:53
-1
Possibly a vent pipe problem.
The vent could be blocked/partial block by outside stuff on top of the roof.
Should have a black pipe sticking out of your roof, there will be others like it. If you hate climbing on the roof (who does't) install air admittance valve.
  • There is no roof vent pipe on the kitchen sewer. The kitchen (ground floor) drains are connected to sewer in the front of the house through a bottle trap. The bottle trap has an open grill on top to prevent any outside debris (leaves etc) going into it. So it acts as a vent I believe. Grill is not blocked.
    – Newbie
    Jan 5 at 0:28
  • @Newbie I would say you are a candidate for air admittance valve.
    – Ruskes
    Jan 5 at 1:05
  • AAVs are A) usually a last-resort solution; B) usually only for kitchen island sinks where a direct vent to the outdoors cannot be installed; C) often actually banned by local code. Rather bold to blindly recommend installing one in this situation.
    Jan 5 at 14:22
