I have a big driveway area in the back of the house. It spans the entire width of the property (40’). I can access the driveway via a common alley that leads to the back of all the neighbor's houses. There's a fence on each side of the driveway. (Here's rough diagram)
| (40' wide) |
| My |
Neighbor | Driveway | Neighbor
Alley (20’ wide)
I want to put in a gate that will allow me to enter the driveway from the left AND the right side. I basically want to drive cars in and out without having to move the other car. (The purpose of the gate/fence is for security and for privacy)
The driveway leads to my garage and is flushed to the right… almost at the right property line. Ideally I would be able to pull in straight into the garage.
I don't want a swinging gate b/c swinging in or swinging out is not a desired solution. I think my best bet is a sliding gate.
I would like to avoid the puzzle of moving cars around to get a particular one out.
I've seen these sliding gate configurations: (A) A 20' sliding gate...the other 20' is just a stationary fence. The sliding gate slides behind the fence. (B) A telescoping sliding gate. The gate opening can be ~75% of the width of the driveway. There are multiple panels that slides behind a stationary fence. (C) ... other options?
How can I configure a sliding gate that will allow me to enter from either the left AND right side of the driveway.
UPDATE Is there such a thing as a rollup garage door that is used for outdoor purposes? Anything that looks good too?
Can I have double sliding gates/panels that’s kind of like double sliding closet doors. Both panels can slide all the way left and also all the way right? What is this kind of gate called?
Accepted answer/solution (Thank you for all of the amazing ideas.) This gate configuration will achieve what I need. Two 20’ sliding gates with a post in the middle. Each gate is on a floor track. There’s a post/guide in the middle of the driveway span. The gates can side all the way left or all the way right. This way I can enter/exit from either side of the driveway without having to juggle cars.
