My furnace pilot is throwing a flame on the flame sensor (or what I believe it to be). The furnace burner is igniting and staying lit for about 30 seconds, then the burner goes out and the blower starts running. If anyone could help me possibly troubleshoot this to the point where I can get heat in my house tonight that would be great.
furnace pilot touching flame sensor
12
  • What make and model is your furnace? Dec 24, 2022 at 1:39
  • Remove the flame sensor and clean it till you have shiny metal.
    – Traveler
    Dec 24, 2022 at 2:44
  • Do not recommend, remove the wires from the over temperature sensor just to see if it is working now and to know if it needs replacement.
    – Traveler
    Dec 24, 2022 at 2:47
  • Make is by heat controller out of Jackson Michigan Dec 24, 2022 at 2:54
  • The model number is CN3D104F29789657 Dec 24, 2022 at 2:55
Change out thermocouple. It’s not generating enough millivolts to keep gas valve open to keep burners on.
  • Your answer could be improved with additional supporting information. Please edit to add further details, such as citations or documentation, so that others can confirm that your answer is correct. You can find more information on how to write good answers in the help center.
    – Community Bot
    Jan 3, 2023 at 8:43
  • I can attest it is true. After routine maintenance, which replaced my old yet functioning thermal couple, my pilot wouldn't stay on. The technician had to come back and replace the defective thermal couple.
    – r13
    Jul 6, 2023 at 19:21
