I am trying to relocate the electrical junction box mounted on concrete wall, and there is a fastener that does not have screw head. It looks nail but with washer underneath which I have not seen before.
Wall-mounted junction box with a rivet-like attachment to the wall
I tried to drill a hole to the fastener on the other side but with no success.
    Think it is called a ramset nail. Uses a special tool to drive nails into cement. Will probably need to grind the head off if you want that box. If replacing the box, using a long ply bar behind the box should pull it out, but the box will not be pretty anymore.
    Dec 23, 2022 at 18:51
I have come across the same problem with Hilti fasteners. BE SURE TO WEAR SAFETY GLASSES when doing this. I have a diamond wheel for my Dremel hand tool. The nail metal is very hard and appears to be brittle. I put a notch and then hit it with a cold chisel, they usually pop off. I will then cut the cement back, repeat the process and fill the hole with cement patching compound.
It looks as if you will have to grind or chisel that head off. Be sure the power is off, wear your safety glasses and good luck.
I ended up prying the whole box with hammer from the back.
  • Can use tapcon screws to install the new box, if it will be on cement wall also. Makes removing again easier.
    Dec 23, 2022 at 20:24
