This long, pointed, gradually wider drill bit from this video seems like an even better method to drill clean holes in MDF than the more common recommendation for brad-tipped drill bits.
What is the name of this drill bit?
drill bit for MDF
Confirmation (following crip659's answer):
To my eye this doesn't look like a spade bit. It looks like it has a peculiar profile. Can you confirm that this is indeed simply a spade bit, and perhaps comment whether a spade bit or a brad-tipped bit is better for MDF?
spade drill bit
  • Your left-hand sketch isn't quite right. Not all spade bits have shoulder points, but no common ones are tapered at such a long angle.
    Dec 23, 2022 at 16:17
  • @isherwood That's a best-effort to draw from a moving object in a less-than-very-well-lit and focused video. Aside from that, and after a bit more image-googling, might the drill bit be a taper-point drill bit rather than a spade bit?
    – Sam7919
    Dec 23, 2022 at 16:23
The bit sides look straight and parallel to me. There's a little light trickery happening, and the debris doesn't help, but I think it's a common 3/8" spade bit.
The side barbs are designed to cut through without blowout if light pressure is used to finish. No need to go inverted with good technique.
A spade bit. Works more like a spinning chisel, with a pointy centre and flat side wings.
