Why does my multimeter show continuity (but no resistance) when not connected to anything?
the scale selector is always for maximum range, so 200 Ohm should read lower values– RuskesDec 18, 2022 at 3:38
2Might be something wrong with it. I have the exact same model and it shows .0L in continuity mode.– manassehkatz-Moving 2 CodidactDec 18, 2022 at 3:41
1Does the OL means open loop (not connected to anything)– RuskesDec 18, 2022 at 4:46
1From the manual: Test for continuity by connecting conductor or circuit with test leads. If resistance is measured less than 100Ω, an audible signal will sound and display will show a resistance value indicating continuity. If circuit is open, display will show "OL". So it has a fault or maybe it is in an electro/magnetic field (that is a wild guess). What if you plug the leads in...do you get 0L?– Steve WellensDec 18, 2022 at 5:45
1I'll note that "no resistance" would commonly be taken to mean zero ohms, which is what you should expect to read across a switch that's "turned on", or from one end of a wire to the other end.– Hot LicksDec 18, 2022 at 14:44
Try creating a proper continuity, then open again, to see if it goes away, perhaps a charge is being held somewhere.
Otherwise, you may have a defective device, caused by measuring continuity while unintentionally applying a voltage, perhaps the line voltage.
If there is power in the circuit you are measuring you will often get continuity. The ohms will depend on the circuits makeup. Continuity should always be completed with power to the circuit off.
2Look at the picture. No wires, so no circuit, so no power. Dec 19, 2022 at 19:12
1@manassehkatz-Moving2Codidact Apologies I did not see them. WIth no probes connected to the meter there is clearly an internal fault in the continuity circuit. Yiu can have the meter calibrated. I believe Klein do a lifetime warranty with their products. Dec 19, 2022 at 20:19
