Just bought a new shower and the 500mm straight arm has no thread one end as it’s designed to cut to size. What connection do you use to connect it in the loft to the 15mm plastic pipe please?
Many thanks in advance.
Andy
  • Product link? Surely, it has its own slip coupling you shove the cut off in? What does it say in the instructions about tools and materials required that are not included?
    – Mazura
    Dec 14, 2022 at 1:37
  • Please take the tour to see how this place works and the appropriate way to say "thanks" and acknowledge answer(s) that help you.
    Dec 14, 2022 at 13:05
You will need a compression fitting, shower arm to plastic pipe similar to the one shown below from Trading Depot. Pipe and shower arms can vary in diameter so your best bet would be to bring the arm and a piece of scrap pipe to your plumbing supply or home store to get a perfect match. It would be much easier to connect if you had threads on both ends. Think about cutting the arm to size and then get it threaded at your plumbing store.
    Threading the pipe sounds great, but the OP did mention that it's plastic pipe. Maybe it can be threaded aftermarket, but it may well be too thin for that. 'tis a good idea if possible...
    Dec 13, 2022 at 13:12
  • @FreeMan I was referring to threading the shower arm after cutting it to size.
    – JACK
    Dec 13, 2022 at 13:28
  • Oh. Yeah. I guess that makes more sense. Goes to get moar coffee
    Dec 13, 2022 at 13:29
  • @FreeMan I'm on my second cup.
    – JACK
    Dec 13, 2022 at 14:12
