This has been a long journey, so I apologize up front for the walls of text. Short story is, when our whole-house (carbon) filter goes through its regen process, it will occasionally result in an extremely loud water hammer that lasts for about 5 seconds, then we have massive amounts of air in our lines.
Our house was built in rural Missouri in 2004. It has 650' well with a 2 HP submerged pump at 500'. We purchased the house in 2020 and had a new water softener and whole-house carbon filter installed professionally by a local reputable company.
Soon after that install the problem I described started. The regen runs at 3a - imagine the hilarity of how scary the water hammer was the first time it happened... The water treatment guys and the well guys know one another, so, after a year of the water treatment guys troubleshooting the carbon filter, they talked to the well guys and suggested a service call.
The well guys pulled the pump and found a broken shaft. They also determined that the wrong flow rate pump was installed for the depth of the well and replaced the motor/pump unit with a new one at a lower flow rate. The original pump was a 15 GPM and they replaced it with a 12 GPM. The water treatment guys also changed the inlet regulator from a 6 GPM to a 3 GPM. The pressure switch and gauge were replaced and the pressure tank in the house adjusted as well, though it is the original tank from when the house was built.
Unfortunately, the problem remains. I'm looking for advice on what I might be able to do to help provide better data or even fix myself. The water hammer is violent and I'm concerned about the damage it may be doing to our water system.
What I really don't understand is where the air is coming from. The pump is submerged and the pressure tank has a bladder. The water treatment guys are telling me that the pump isn't kicking on quickly enough and is sucking the pressure tank dry, which is introducing air into the system. I just can't wrap my head around that.
I appreciate any thoughts / experiences you may have.
Thanks,
j
