I am trying to piece together the 1960s-era wiring decisions in my home and am a bit stuck. I discovered a multiwire branch circuit at the panel (wide 2P 15A Siemens breaker, correctly spanning both phases and mechanically connected handles).
Altogether, when I flip the large handle on the 15A breaker it kills 13 receptacles and 6 overhead lights. I haven't removed every cover, but I couldn't see any 3-wire Romex anywhere and everything has just one hot and one neutral. I'm assuming that the neutral is split in a junction box somewhere that I also haven't found.
Is there a way (ie a tool) to test the voltage between receptacles to see if I get 0 or 240V (indicating they are on the same or different leg), or a different way to detect the phase of each receptacle? This will help me figure out if/where I can add more receptacles to avoid overloading the circuit.
