What are the reasons for using something like Quikrete's Quik-tube for pouring footings for posts rather than just pouring directly into the ground with a galvanized anchor set into the top of the concrete?
One thing I read is that the tube holds moisture to allow for stronger curing, but are there other reasons aside from that or perhaps if you wanted the concrete to be above grade?
It seems like it'd be nice to have the concrete fill all voids in the dirt to provide more lean strength.
