My understanding is that Greenguard needs to be covered by a thermal barrier like drywall when you install it. Is there a way to use a leftover piece of Greenguard to make an attic access insulation cover safely?
Sure can. The Green XPS foam board is very versatile, but it should never be used to walk on. However, it can work just fine in multiple layers as a ceiling access drop-in panel. Any other use for floor or wall access must be inserted into a frame that is structurally sound for the application.
  • do i need to add a thermal barrier to it if i use it that way? i don't intend on walking on it
    – nikolifish
    Nov 29, 2022 at 3:22
  • No, that would suffice as both your insulation and removable panel. You should still glue or tape 2 or 3 layers together for better insulation and durability.
    – Iggy
    Nov 30, 2022 at 0:38
Sure it can. Greenboard IS drywall, but it has a thicker paper shell that's coated with wax to make it water resistant. It's typically used in high-humidty locations such as bathrooms. However, it's not water-proof and shouldn't be used where direct exposure to water is expected (such as a shower stall).
    I think OP was asking about green foam board insulation (XPS). I know he said Greenboard, but reading the rest of his question he's asking about insulating an attic access hatch.
    – SteveSh
    Nov 29, 2022 at 2:30
  • This is exactly what I was thinking as I started reading the question. I'll give it a +1. Heck, there is some amount of insulating property in greenboard/drywall, so maybe this is what the OP means...
    Nov 29, 2022 at 18:20
  • Yeah, I mean greenguard, not greenboard. Sorry for the confusion
    – nikolifish
    Nov 30, 2022 at 17:18
  • Title changed to remove "greenboard" Nov 30, 2022 at 17:21
