The can appears to be seated correctly and screwed in firmly. And yet it is leaking foam around the adapter - I saw it starting to slowly ooze out along the mating surface immediately after screwing in the can.
Is this a problem with the gun, or the can, or both? I've already flushed out the gun with the special can of solvent, and the gun dispenses freely.
For reference, this is the Great Stuff Pro 14 model gun. I've tried a cheaper model of spray foam gun in the past, and had this same problem but even worse. The can refused to seat correctly at all, and blew foam all over my floor before I could get to a trash can. I haven't seen anyone mention this issue anywhere else, which makes me wonder if I'm just doing something wrong.
