I'm planning to have simple storage on the attic above the garage. The size of beam I measured is 2x6 and around 11 inches apart. I will only work on the 2/3 of space to avoid the area with wires.
I'm wondering, for storage purposes...
  1. What size plywood should I use?
  2. Can I just set them on the beam without nailing them in?
Thanks.
First, you should determine if your garage structure can support storage at all. The length of those 2x6 that are 11 inches apart (odd spacing, if accurate) will matter quite a bit in that. Or the drawings for your garage when it was built will actually tell you explicitly. 12 inches on center would have space between the joist faces of 10.5 inches, which would be "around 11" but also a more normal joist spacing...
For 1, normally whatever the stock size plywood sheet in your part of the world is - 4 feet by 8 feet is normal where I am. Sometimes for attic projects they need to be cut smaller to get them into place.
As for 2, you'll regret that when one slides off the joist and you step on it, it tips, and you fall either until you hang up on the joists yourself, or all the way to the floor below.
  • You only do 2 once. You make sure the nails are in after.
    Nov 25, 2022 at 19:34
