Why separately ground the device case?
I had some work to do to install network devices in a rack. And in the course of work, I had a question. I had a Cisco switch in my hands, on the front panel of which there is a separate output for connecting to ground.
Judging by the description, I have to connect it to the rack itself in which it is installed. Why is this being done? Power is connected to the switch itself, which already has a ground line (C13 connector). And all devices in the rack, in theory, should already be grounded, since all are connected to a powerline that already has grounding
P.S. It is also worth noting that not all devices have such a pin, for example, on a router (cisco) I did not find such a separate ground pin
