enter image description hereI was able to completely remove all of the handle down to the stem. I’ve spent the last 4 hours reviewing videos on what I should do next and am at a loss. None of the stems on the videos look anything like my stem.enter image description here
Don't pry anything. This looks like a Moen, and probably the shiny lamp-shaped part screws off, either by hand if you have a good grip or with a strap wrench. After that, the valve stem can be removed with a channel lock.
Search "change moen widespread washer" on youtube for lots of demos.
The bottom part, beneath the shiny lamp-shaped part, holds the valve assembly to the counter with a nut from below. If it's tight, don't loosen it. You don't need to remove the valve from the counter top to change the washer.
  • Thank you very much. Now that I know how it’s seated, I can follow your suggestions and work from there.
    – JDTurk
    Commented Nov 20, 2022 at 0:31
  • I was able to completely remove all of the handle down to the stem. I’ve spent the last 4 hours reviewing videos on what I should do next and am at a loss. None of the stems on the videos look anything like my stem.
    – JDTurk
    Commented Nov 22, 2022 at 22:08
  • Add a pic to the question.
    – jay613
    Commented Nov 22, 2022 at 23:13
