When repairing my furnace I inadvertently ripped out a quick-connect terminal from the black cylinder (probably a capacitor.) The male end at the end of the capacitor is basically a long, sharp, pin (obscured in the photo by the remnants of the quick connect before I removed it, and the female barrel end (surrounded by heat-shrink tubing) is as shown in the second photo. The female barrel diameter is about 1/16"
What type of connector is this?
Male end/capacitor
Female barrel end
    I take it said connector went out to a spark ignition lead? Nov 15, 2022 at 2:07
  • probably custom make
    – jsotola
    Nov 15, 2022 at 3:08
  • @ThreePhaseEel you take it correctly. Does that help identify the type of connector? Nov 15, 2022 at 4:39
  • Brand/model of the furnace? With that, someone could look up the instructions and/or parts list. With the parts list, you could then figure out what the replacement part is and order it...
    Nov 15, 2022 at 16:08
