I recently installed luxury vinyl plank in our kitchen. Prior to the installation, there was a section of hardwood and a section of carpet. I took out the hardwood so that I would be able to have a level surface for all of the LVP to be installed on.
The hardware was glued down to sheets of particleboard and pulling up the hardwood did a lot of damage to the particleboard. I did what I could to fill in the bumps, but after installing it, there are sections where it just feels uneven to walk on, with slight divots in different places. If I could go back, I would have cut out the particleboard under the hardwood and replace it with new particleboard.
I’m concerned that these divots might cause damage to the LVP over time, and of course I would like it to feel a bit better to walk on. Has anyone been in a similar situation to me? Did you leave it as is and was it fine over time? (I feel like I might be extra sensitive about walking on it, because it was just installed). Would it be worth dismantling the LVP and putting new particleboard underneath the uneven section?
