I have a new kitchen hood with a vent duct slightly larger than the existing one and I need to "roundly" enlarge the hole.
What would be the best power tool(s) and accessories to be used for this work?
pic1
pic2
  • How large does the hole have to be? What are the walls made of?
    – JACK
    Nov 4, 2022 at 23:37
  • the whole needs to be enlarged by 3 mm (1/8 inch) all around. The walls are made of hollow brick with a layer of .. mortar/concrete? at the inner side Nov 4, 2022 at 23:39
    Large hammer and chisel and just pick the hole larger
    – Chris
    Nov 5, 2022 at 0:06
  • @Chris: I did something similar, I used a flat head screwdriver with a hammer and chiseled delicately away but thought to myself to ask on this site for opinions though. Nov 5, 2022 at 3:10
    you can pre-drill in front of large chunks to control splitting and make it easier to chisel. if you don't care about the bit you can drill the whole thing out like a dentist...
    – dandavis
    Nov 5, 2022 at 9:58
You don't even need a power tool. Just one of those rough files is all you need.
Hope this helps.
Take care.
coarse files
    Be sure to get a rasp designed for stone… the wood ones won’t last long. Nov 5, 2022 at 11:06
1/8" isn't much to enlarge.
I'd probably go with a 4.5" angle grinder with a masonry grinding disc something with a large kerf.
