This is my first attempt at sealing a window frame with expanding foam (I used the kind for windows and doors).
I cut off the excess with an oscillating saw blade with teeth, and I'm a little alarmed at the appearance - are all these bubbles OK?
Would I be completely silly to cover it up with some self adhesive aluminum flashing (the kind you'd normally see on the outside)?
