So I put a very large island in a house that has a dip in the floor - where the middle part of the island is maybe 1/4" low than the outside edges.
One side is 4 large base cabinets. One side is 3 uppers. Three uppers means I had to create a base. Reasoning for the uppers is that having another row of base cabinets would have been way too wide and it took about 2k off the cost.
So the install steps were:
- Get the tops of the 4 base cabinets lined up and screw them into each other.
- Shim front and back to make it level length and width wise.
- Add 2x4 blocking inside along the back edge.
- Once fully shimmed screw in the back.
- Note (learned after a 20 minute u-turn)... Measure the front of the sides length wise (not the front lip) and make sure it is exactly the same as the back of the sides. 1/16" bowing over four cabinets is 1/4"!!
- Cut and plane a 2x6 to attach to the back bottom of the base until the three uppers are slightly below the backs of the cabinets.
- Cut and plane another 2x6 for the front.
- Add 2x4 blocking to the floor to keep corners and 2x6s in place.
- Cut and plane the sides and install flush with finished base cabinets.
- Run electrical under where uppers will be installed (doing this after all blocking was easiest).
- Put uppers on planed back 2x6... Shim them to exact even with back of other side. Screw them into the top of the uppers to top of base.
- Once sides are lined up and happy install front 2x6. Screw it into blocking.
- Add side panels.
- Add corner trim to hide cuts near toe kick.
So the question is... putting 7 big cabinets together in the middle of a dipped floor seemed like an exercise in futility. 50 shims later and planing down to the miniscule details made the project almost 3 days and I was expecting to have it done in a day :). Please share mistakes I made or tricks to make this process faster.
