I recently installed new Kasa dimmable light switches (HS220) along with new light fixtures with LED bulbs (E12 2700k Candelabra Light Bulb). The bulbs are dimmable and 99+% of the time they work as expected. But every so often, when on a dimmed settings all the dimmed lights (I have 3 fixtures, 16 bulbs, on 2 different circuits) in unison, start flashing between max brightness and the dimmed setting at maybe 10-40 hz for 5-10 seconds, then go back to their dimmed setting.
Being that they all do it at exactly the same time and frequency across 2 different circuits tells me this is likely an issue upstream, say at the meter, or the incoming power lines, but in any case, my question is how do I get this diagnosed and fixed?
Video of an oscilloscope showing the voltage change when normal and while the strobing is happening, this is pulled from a plug that doesn't have any lights on it: https://youtu.be/Jq2ioIMUwhM
