So we have two once beautiful, but now both irrepairably worn, and unsustainably badly insulated doors on the house. They are non-standard size, and reside in an arched opening, with fixed window on the top.
The cost to replace them, even with an almost half-price discount is way too high - I can buy 5 quality standard size doors for the same amount.
So I checked, and in theory, it would be possible to have ordinary, standard size doors fitted in the place of the current ones, the opening is luckily large enough.
Securing the sides of the door frame seems to be OK - can be done with the standard long screws going into the wall. It even seems that I can use the wood of the original doorframe on the sides, meaning less waste.
I'm unsure about the the top of the frame. What should be put there? Would a thick enough piece of wood be enough? And how to fix that to the wall/remaining wood frame? Or should I put an iron "beam" there, cover it with wood, and use screws to fix the top of the door to that?
