My wife and I found this problem where we want to replace a new work box? with an old work box that will allow for a new outlet to be place in there, however the old box is attached to this metal bracket which is nailed into a stud. I was wondering how would we go about removing this?
Frontal of Outlet Box Wanting replacement
Side view of outlet box
Get a crowbar or pry bar and pound it underneath the nails and pull them out. If you have a rotary tool with a cutoff wheel, you can cut off the nail heads and avoid all the pounding. An angle grinder will also do the job. I'd replace it with a new work box since the stud is exposed. The new work box will be stronger.
    Agree and will add that an oscillating tool (“Fein” for us oldtimers) would also do well for this. Oct 23, 2022 at 13:20
