I replaced a shower head in my home, replaced a million before. I applied the tape, wrapped it around the grooves on the goose neck hand tightened the shower head, then put duct tape around my adjustable wrench and tightened with the wrench 2 qtr turns. BAM!
So I thought, coming from where the arrow is, the bottom side of the new shower head, there is a contstant stream of water when the water is on. I've got the shower head pretty tight,should I go tighter? More tape? What do I need to do here?
