I turned off the water at the main when I turned it on I noticed a constant drip from the shower when it is off
How can I stop the drip and balance the water through out my house
  • Your shower has a leak. Will need to fix the leak. Water is already balanced.
    Commented Oct 19, 2022 at 22:35
  • This is stating the obvious, but did you try turning the shower on and the back off again? Sometimes that fixes it, sometimes not. Commented Oct 19, 2022 at 22:45
  • open the shower and release the air pressure
    – Traveler
    Commented Oct 19, 2022 at 22:47
  • What does "balance the water" mean? What would you be attempting to achieve by doing that?
    Commented Oct 20, 2022 at 14:12
This is frustrating to deal with! Luckily, it's usually an easy fix.
Most likely, you have a bad valve. This is something you can do yourself, or have an experienced friend take care of. Not something you need to call a professional plumber for (although you can if you'd like the warranty of their work)
Here is an article that goes into more detail about it and it even offers a how to guide if you want to tackle this project yourself. https://www.hgtv.com/content/hgtv-com/en/how-to/home-improvement/articles/2020/how-to-fix-a-leaky-shower-head.html
Just in case, here is another place you could look: https://www.homedepot.com/c/ah/how-to-fix-a-leaky-shower-faucet/9ba683603be9fa5395fab9016cbb4f8c
Be sure to turn off the water supply before you do anything. Also, depending on your style of shower, you will need a screwdriver and/or hex tool and a wrench.
-Once the water is off, remove the handle cap, handle, and faceplate.
-If your shower has one, remove the locking clip (Not all showers have this).
-Remove and replace the cartidge/valve
You could also take this opportunity to replace other shower parts that have suffered wear and tear. Even though they may still work.
Hope this helps!
    As with every SE site, this is, essentially, a link-only answer and is useless when HGTV rearranges their site. Please edit to include relevant bits from the link.
    Commented Oct 20, 2022 at 14:13
  • Your answer could be improved with additional supporting information. Please edit to add further details, such as citations or documentation, so that others can confirm that your answer is correct. You can find more information on how to write good answers in the help center.
    – Community Bot
    Commented Oct 20, 2022 at 18:11
