TLDR: New windows appear to be too small for the frames. Is setting them on the previous windows frames acceptable as show in the images below?
Apologies in advance for mislabelling window parts...
So story is that I recently bought this house that was built in the 60's. All windows have been replaced except the basement windows. I was recently contacted by my realtor stating that a contractor (now deceased) hired by the previous owners ordered 6 new windows to replace them which is great as they are all currently single pane. However, I just went and purchased them (1 year after ordering), and it appears that they all may be too small.I know typically you would knock out all existing remnants of the old windows, but I fear that if I do, there will be at least 2-3" of space surrounding the entire window. It appears the contractor must have ordered a size to fit within the existing frame. Anyway, I went ahead and tried one which is what it looks like below. It fit nice and snug, but it looks a bit odd on the outside. The wood is exposed and the depth seems deeper than normal. Is this proper and efficient among other things? And how would you go about replacing if you were to knock out the entire old frame? Thanks!
