My house has a gas hob other than that I don't have any other appliances which burns off fossil fuel.
I have other heavy appliances like washing machine ,Electric OTG Microwave oven, Fridge,Toaster ,Electric water heater for bathroom, AC(R32 refrigerant) and an inverter but these won't produce carbon monoxide anyways.
So do I really need to buy an carbon monoxide detector ? I mean like if the flame cooler changes from light blue to brownish I'd know that carbon monoxide is being produced may be due less ventilation(oxygen) or low levels of gas(LPG).
May be I should be investing on Gas detector which can detect the leakage of any gas like R32 or LPG from gas cylinder. I know I might be able to find LPG gas detector. But is there any detector that can detect R32 gas leak from AC ?
Any advices are highly welcome
    your answer is in the question, Is your life worth the cost of the detector?
    – RMDman
    Oct 15, 2022 at 13:13
    It is insurance. You never need or want it till 5 minutes after it is too late. CO gas is odourless and colourless, so the only time you notice is just before you pass out for the last time.
    Do I really need fire insurance, car insurance? You make the choice.
    – JACK
    Oct 15, 2022 at 13:25
    My house has a gas hob so, you clearly need a CO detector. Or you can die just like the old days before there were such things, as you wish, suject to possibly breaking local laws, if applicable, but you'll be dead, so...
    Oct 15, 2022 at 13:39
    Read this and decide for yourself. abe.iastate.edu/extension-and-outreach/…
    – mkeith
    Oct 16, 2022 at 19:49
I'd get a combination CO/flammable gas detector if I were in your shoes
Given that you have a gas combustion appliance (hob) that's probably more vulnerable to inadvertent leaks and malfunctions/misoperation than a fixed appliance (like a water heater or a furnace), I would recommend a combination CO/flammable gas detector -- I have a Kidde KN-COEG in my house, although you'll need to look around for something suitable for your 230V mains as the KN-COEG is a 120V unit.
  • We have 3 phase residential electrical connection.
    – CuriousMan
    Oct 15, 2022 at 15:19
  • @CuriousMan -- what line-to-neutral voltage does your house run at? Oct 15, 2022 at 15:22
  • If you leave the windows and doors open 24/7 then you will not need the CO detector. The end result is you will probably burn the cost of the detector every few days in heating or cooling bills with everything open. To live the most inexpensive solution is to install the CO detector.
    – Gil
    Oct 15, 2022 at 15:38
    @ThreePhaseEel - 230 volt
    – CuriousMan
    Oct 16, 2022 at 12:45
Yes, you need a CO detector.
This is cheap insurance against an odorless gas that will kill you.
Where I live, it’s a code requirement.
Also where I live, you can get one for $30, and it lasts 10 years. $3 a year.
    About thirty years ago a decent size family died because of CO. A year or two after the province made it a law that every house as a CO detector. Did not wait for code to change.
    Oct 15, 2022 at 17:56
