I recently bought a dehumidifier with built in pump for my attic. There is an HVAC unit in the attic with a condensate drain pan and drainage pipe. There is (what I think is) an open access point in the pipe, and I'd like to run the dehumidifier's pump tube into this access point. Is this kosher? Is there a better way to do this? Thanks.
Photo here: https://ibb.co/1fBfVKT
Sure, but the risk is that if the condensate drain gets clogged then you're pumping water into your air handler. The vent is there for a reason, so don't hard-connect to it, it needs to be functional. Just run a smaller diameter tube to it.
