the shower unit reads: 220v-5500 30A 4mm2/10AWG .
The present wire installation is 30A breaker with #10 wire for about 30 feet, connected to #12 wire for another 6’ to the shower head.
  1. Can I use this shower unit on 110?.
  2. with 20 or 30 Amp breaker?
  3. With the same wire installation?
  • A picture of the name plate on the heater, a link to the instructions, and a picture of the heater itself, all edited into the question would help a lot.
    Commented Oct 10, 2022 at 14:57
  • If I add another 6’ of #10 to the shower head, instead of the #12 is that a solution? Commented Oct 10, 2022 at 14:58
  • Where are you? Electrical service is 120/240V in the U.S. I assume you wouldn't have mentioned 110 if you weren't in the U.S. Is your unit intended for the Euro market? Specs of 220V are not common (though 230 is).
    Commented Oct 10, 2022 at 15:01
  • You can't upload images until you have some reputation. Upload to somewhere else and put a link in your post.
    On 110/120, you'd only get 1350W (Half the volts, so half the current, so one quarter the power.)
    Commented Oct 10, 2022 at 15:51
