Am replacing a single pole switch with a smart switch. The single pole I'm replacing has two wires on one terminal, a single on the other. The single wire is live, and the two wires are load.
The smart switch has ground, neutral, live and load wires. Unfortunately the instructions are not the best, but include a diagram.
I'd like help on how to make the connections. Feel safe to connect ground-ground, and believe I would connect the live from the smart switch using the live wire from the original switch.
Am not so sure with the neutral and load wires on the smart switch. Do I connect the neutral to the neutral (white) in the box? And for load, am thinking I pigtail the two existing wires and then connect?
Any help would be very much appreciated.
