My sink has an inbuilt draining board like this.
The draining board is useless to me because I also have a dishwasher, which drains the dishes after they are washed. Small jobs get washed and dried by hand and then put away immediately.
The problem is the draining board takes up valuable counter space. I would rather have just more counter where the board is. But short of replacing the entire counter top this will not happen.
Is there a good way to turn the drainer space into usable countertop? I could of course slap a chopping board on it but the chopping board will wobble on the metal surface. What is the next easiest solution?
    Uh...Just put things on it...it's a slightly ridged metal countertop. You're overcomplicating this. You won't even need a trivet for hot things!
    Oct 4, 2022 at 22:12
    @Ecnerwal But the things will be gasp wobbly!
    – Daron
    Oct 4, 2022 at 22:21
    Big enough chopping board to reach all the way from the front of the counter to the back, then...completely spanning the drainboard area.
    Oct 4, 2022 at 22:24
  • + for Ecnerwal's cutting board. Put some nylon feet on it and you can stand it behind the faucet to dry after you wash it. Water draining off will drain into the sink thanks to that nice little lip your sink has.
    – Willk
    Oct 4, 2022 at 22:37
  • I’d put in a nice big sink instead, but that also sacrifices counter space.
    – Jon Custer
    Oct 5, 2022 at 0:01
I really don't think you need to do anything to this area to use it as countertop. But if you insist:
Big enough chopping board to reach all the way from the front of the counter to the back...
Put feet on it to raise it up a bit if that seems needed for stability.
