I'm wondering if I will be able to just pull single wires since I'm going to be putting the wires in conduit. I'm going to need 120 V. I was also wondering if my box is metal, would I just be able to ground outlet to the box and not need another ground wire going back to the breaker box?
Metal conduit can be used/is used as ground. Extra ground wire is not needed.
If plastic boxes are used, think there are ground connections to attach to conduit.
From other questions on here, a cable is much harder to pull though conduit than wires.
Need wires made for conduit, can't just strip the outer covering from a cable and use those wires.
