I just had my basement concrete redone and the guys got a lot of concrete on the painted walls. I want to make sure that my paint sticks well to the concrete wall and I don't know if it's going to do that with all the concrete splatter that's there.
I can run my hand down the wall and it gets all dusty.
here's the wall I'm talking about
Lightly brush and vacuum off the dust. Then cover the fresh concrete with a clear pre-paint sealer. When dry you can paint as you would any surface.
  • I would suggests "thoroughly" brush off the dust & vacuum it up. Maybe even a wipe down with a damp rag if it's really dusty. Paint that sticks to dust will fall off sooner rather than later.
    Oct 4, 2022 at 12:21
  • if you use sealer there is no dust. you have a sealed area primed for paint.
    – RMDman
    Oct 4, 2022 at 12:44
    Does the sealer manage to magically make the dust stick to the wall? Even if it does, you're left with a rough paint job. Granted, OPs wall isn't the smoothest thing ever and he doesn't seem to be concerned, but on general principle...
    Oct 4, 2022 at 12:46
  • The answer is yes. pre-paint concrete sealer is low viscosity but very sticky. It's purpose is to bind the loose particles together to the surface it is applied to and provide a proper surface to apply paint. it's science, but I guess you could call it magic.
    – RMDman
    Oct 4, 2022 at 12:53
  • Adding those details into your answer (for those of us who don't know that) would make this a good answer and get my vote.
    Oct 4, 2022 at 12:57
