There is a wooden staircase going from the kitchen to the basement in our house. A small gap has opened up between one of the steppers (the part of the stair case you step on) and the stringer. In addition, there is a small amount of squeaking when you use it.
From a cosmetic point of view, I think it is fine. I looked at the bottom (e.g. underneath it) and it all looks fine. However, I am worried about a safety issue. Should I be?
A picture
Here is another picture:
A closeup of the gap
9
    Only unsafe if someone(teens) sneaking up or down and know about it and skip the step. No pictures so will suggest adding a couple of screws to tighten it. Good if unfinished, not good look if finished. Reminds me I have a 40 year step I need to fix.
    Oct 1, 2022 at 20:07
  • @crip659 I added a picture.
    – Bob
    Oct 1, 2022 at 20:22
    Carpet should hide screws. Stain or paint don't hide screws as well, without more work.
    Oct 1, 2022 at 20:25
    Stepper to stringer uses shorter screws(~2 1/2 to 3 inch).
    Oct 1, 2022 at 21:35
    Stringers are under the ends of the stepper/tread. Drill pilot holes and screw down. No removal needed.
    Oct 1, 2022 at 22:03
The modern way to install stairs is to do a rough stair case first with stringer and treads / risers. The next thing is to put your skirt board against the wall. The stair stringers are not visible from the top. The finished treads/risers are then install on top of the structural treads/risers and horizontally against the skirt board.
It is hard to see in your picture but possibly these are rough stairs with green carpeting installed ( though the tread bullnose makes me think otherwise )
As far as safety, assuming the stairs were built with proper fasteners, even a 1/4" gap is not going to constitute a safety issue. I can't tell from the image how wide the gap between the tread and the skirt board is.
  • The gap is about 3/16 of an inch. The house (and the staircase) was built in 1962.
    – Bob
    Oct 2, 2022 at 13:40
Around Oct 5, I noticed that the problem was getting worse. One of the risers had a gap in it. Therefore, I decided it was not safe. We brought in a carpenter and he agreed that it needed work. We hired the carpenter and he fixed the problem.
